DAYUM! Not my style rims, but size and brand is a :smt041
Rears will work with rolled fenders to the max, SUPER stretched tires, and CRAZY CAMBER.... Simply Beautiful
Ive been pondering the thought of changing rims and im starting to feel this VIP look Silly's been wanting to do. I know staggered is not for fwd cars but im strictly going for looks. My question is i see some rims i like but im not sure if they will fit...imma pull and roll the fenders as much as i can and i will be leaving the rear cambered but only if these rims will fit. the fronts im pretty sure will fit, im just curious about the rears...
they are work VS-KF 19x8 +38 front and 19x9 +33 rear
Here is a 19x9.5 in the rear:
As you can see, they fit when the car is static. Don't think they will fit when you take into consideration the compression when the car moves up and down. Even if i stretch tire and roll/pull fenders, i still don't think it would work. But i must agree, 9 inch rims in the rear look SICK :shock:
^ thats sexy, if that fits ima sell my set and get a 9.5 also..look were the works family..
00 Galant ES Turbo/5-Speed
13 GTR
ive been seriously considering doing this....im still lookin at other sets of rims. Its just hard to drop that kind of cash when black friday is coming and i had my heart set on a 50 inch samsung widescreen. if i was to get that size rim in the rear...im assuming i would have to run a 235/35 or wider. not sure if they make a 30 series, might be too thin.
those are some heavy mofos. but wtf, try it. i wanna see it.
-Pedro
what offset is that guy running? imma see if i can find rears closest to his offset
my wheels are 19x8.5 with a +38 offset all around, the fronts will stick out without the jdm fender flares, with them the will sit perfect and just a few mm inside, the rears sit inside just a bit of clearance so im not wsure if the 33 would definatelly work either maybee like you said with an extreme fender roll or cutting away to make them fit....those wheels would definatelly be a really tight squeeze though and you would need coiolvers or bags or something also to make them drivable
roll fenders.. add camber... go
but make sure u have coilovers anything else wouldnt be stiff enough
i'm only running 19x8" .42 offset with my rear semi rolled. it's really hard to tell wether they'll fit or not. Just get one of the rear tires on there and test fit adjusting and cutting as needed. I would play it safe and just cut my rear fenders before even putting them in.
edit:
tien s-tec drop
-Pedro
If u cut inner rear fenders, better make the edges dull or if you DO RUB, you could blow ur tires. Like I said before, roll em good, camber it out...you'll be fine. the badder the camber, the less life of the tire, but the more props you'll get....well that is, if ur slammed beyond being able to put ur feet under ur sideskirts 8)
the front will still stick out though unless he runs a pretty negative camber that would be pretty noticeble
i do like the wheels but i would go with something that will fit a little better in the same style if possible
well im running an 18x8 with a +38 offset right now front and rear and its pretty flush. i dont know if 19x8 will be any different. kali...that drop is nice...i wish my s-techs dropped that well...i still have a gap...but thats gonna change...im trying to work out a megan coilover deal as we speak and dump it to the ground. im going to tuck 19's and if it dont tuck imma take out one of the collars and and drop it more to make it tuck.
