Thread: Hey Guys New Pics Of Whats Coming Up...Some new pics
Page 15 of 31 FirstFirst ... 511121314151617181925 ... LastLast
Showing results 281 to 300 of 607
  1. #281
    You are here entirely tooo much!! Serstylz2's Avatar
    09-10-2003
    Charlotte, NC
    4,462
    yeh i think i gotta bronze my rims this winter, looks too good
  2. #282
    Quote Originally Posted by alexvr
    u prolby said if alex can do it i can do it lol looks great, wat paint did u use? primer sealer primer or clear?? niice, lets see when me u n david can meet up
    haha yea u actually influenced me to do it...lol...i used high heat paint 500 degrees...primer and gold...no clear...so far so good...paint holds up after rain and dirt being on them...let me know when u guys wanna meet up...im always up for anything.
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
  3. #283
    Senior Moderator mrjaydeeone's Avatar
    07-31-2002
    Woodbridge NJ/Staten Island NY
    4,455
    looks good. nice color choice
    Jason - - cofounder of TGCNY
    click banner to enter the NY Chapter
    2001 Galant ES
    2004 Jeep Grand Cherokee Special Edition
  4. #284
    TGC Regular djflex167's Avatar
    07-21-2007
    Manhattan, New York
    709
    Quote Originally Posted by whokilledhoughes
    Quote Originally Posted by Da_silvagride
    If you don't mind me askin. how much did you get the whole set up for. Thanks
    well if i remember correctly...
    heads=280
    bumper=567 shipped from japan to california to miami..
    fogs=around 380 shipped
    grill=165
    lips=180
    sideskirts=350
    paint job on everything. 980
    2902 so far...im preaty sure u can get them for less if u really look around...but its still not going to be cheap, expect to pay atleast over a grand minimum...
    well just wanna say i got everything back from the shop painted...the guys fucked up on the grill so hes re painting it i should have it back sometime this coming week...ill take shots of it soon..
    so you paid 380 for the fogs only? and 567 for the bumper?
  5. #285
    Quote Originally Posted by djflex167
    heads=280
    grill=165
    lips=180
    sideskirts=350
    yes sir...got them from cali...a little pricey...but hey...he did me that favor and got them to me...i know i could have asked trigger...and he has helped me before with other parts...but what happened happened.
    Fully Built 4G63
    HKS 272
  6. #286
    07-21-2007
    Manhattan, New York
    709
    atleast u have them with u bro and thats what matters here!!
  7. #287
    well...i decided to test fit the turbo today....and as i thought....no good...the turbo will not mount on with the stock manifold off an evo...gonna have to go custom or use a tubular manifol already made from an evo..
    these pics are from someone that did the same set-up over at club3g.com its DNS-EN's set up..
    from what i know about his set up is that he is using the spacer at an angle which i have made already and non-modified after market manifold off an evo...
    if you notice he still has the starter sheild on with no problems at all...my main question is if anybody knows...what is the difference between the cast iron manifold and the tubular one...from the pics above we can see that the tubular one sets the turbo slightly more upward than the cast iron???when i went to test fit...the cast iron manifold was only hanging on to to the left side of the block and would not reach the right side studs due to the damm starter being in the way...i would really hate to get a tubular manifold made from an evo and not fit which i dont see why it wouldnt fit due to the pics above...or i can just have a custom manifold made...what do u guys think???
    Fully Built 4G63
    HKS 272
  8. #288
    08-08-2004
    Las Vegas
    2,098
    if you look at the first picture... look at the bottom left corner of the manifold, he has a spacer thats why the manifold angles upwards and clears the starter.
    you will need one of these
    and you need to hav the flange ground to 1/4" on the top and 3/8" on the bottom so that it angles the exhaust up slightly... and you need longer studs.. i believe http://www.ssstuds.com/ has them
  9. #289
    04-10-2005
    NYC
    3,695
    actually i think you will need 2 at least thats what goosey had to use
  10. #290
    08-08-2004
    Las Vegas
    2,098
    i thought it was only one but if its two, why not save yourself some trouble and weld a little length of pipe inbetween the flange and the runners to push it out away from the starter more
  11. #291
    Quote Originally Posted by underated
    i already have that spacer at an angle...i got some extended manifold studs and did the spacer at 3/8 on the top and 1/2 at the bottom which gives it the same angle as 1/4 top 3/8 bottom...thats not the problem im having...its the STOCK manifold that does not even reach the block on the right side (it will not mount onto the studs and he is using a tubular manifold not the stock cast iron) due to the cold side on the turbo hitting the starter nasty style...anyways...i might be going with a custom manifold my local shop might make for me and go from there...
    Fully Built 4G63
    HKS 272
  12. #292
    correction...just found out you cant use the stock manifold...unless you get two spacers or something like that...i need an after market tubular manifold with the spacer...or have the flange cut out and re-welded at an angel to push the turbo away from the starter...
    getting this bad boy here....DC-Sports Brushed Manifold... :twisted:
    Fully Built 4G63
    HKS 272
  13. #293
    Double post...
    Fully Built 4G63
    HKS 272
  14. #294
    got bored and took some more pics...
    Fully Built 4G63
    HKS 272
  15. #295
    Experienced TGC Member Divinity's Avatar
    05-01-2007
    Jacksonville, FL
    1,281
    Is that a dash mat I see? :shock:
    Car looks awesome
    ~Lady Driven~
  16. #296
    Quote Originally Posted by Divinity
    Car looks awesome
    yes it is...ive had it for a year now...lol...dash is cracked down the middle so i bought that for the mean time... :) it also hides all the wiring from the gauges in the middle.. 8)
    Fully Built 4G63
    HKS 272
  17. #297
    TGC Regular
    04-07-2006
    Hialeah, Fl
    594
    looks awesome, i wonder how it looked minus the wings and the window visrors
  18. #298
    07-21-2007
    Manhattan, New York
    709
    i love the rims, hood, evo wing, i could say everything looks nice!! great job man!!
  19. #299
    :smt041 HOORAY 4 DASH-MAT :smt041
    Looks clean (the car )
  20. #300
    Hey man I knew I recognized that car!
    You are the sole reason for why I got a Galant in the first place! I visit my dad every once in a while. He lives in Country Walk. I saw your car parked outside of where you work (I don't want to say where). I think my dad even asked you for your number so I could talk to you to see where you got your front bumper and skirts. Your car is beautiful. I really hope trigger can help me out with getting the bumper here. Seeing this car really gets me excited. I want my car to look just like that!!! :D
