Great tutorial bro.
DISCLAIMER: If you break your mirrors, it’s on you! I take no responsibility for anyone’s actions and the results of your own doing.
Tools you'll need
Remove the rubber gasket
Remove the screw holding the metal clip thats holding the wire
Cut off / remove the plastic connector
Uscrew the 3 bottom screws. NOTE: These are threadlocked screws so you have to use a High-Torque Electric Screwdriver to remove them
Push the top of the lense up by hand
Insert a flat head screw driver between the white braket and the lense then slowly pry the lense up
Then with fingers pull the lense out of there
Remove all the screws marked with a red circle using a phillips screw driver NOTE: DO NOT REMOVE THE CENTER SCREW
Move the attached assembly aside, do not unplug
Remove the other 2 screws
Carefully using a flat head screw driver pry the little tab on the bottom corner and remove the bottom cover of the mirror
Remove screw to release the motor
Remove the Last Screw
Done!
Great tutorial bro.
Sorry, I don't get it, whats the point of taking it apart? Do you need to take it apart before putting them on the 8g or something?
Also you should be like the other threads... and put a disclaimer for not being liable for damages.![]()
'o4 Acura TL: Dynamic ;; AEM | P2R | Falken
Sound.Vision.Soul // Drive.Drift.Dream
It is because his motors went bad so he swapped them in so he didn't have to repaint the mirrors.Originally Posted by komodo
P>S> I told you it can be done roman![]()
2000 Galant ES = Daily Driver
Ohh I see. Makes alot more sense now. Thanks.Originally Posted by Sleepervr-4
if you want to take them apart this is how. Otherwise don't. Angel is correct, one of my motors took a shit on me awhile back and i'm finally replacing it.
what does the motor look like? is it just one of those round or rectangle ones like at radioshack?
nope, nothing like it. its all 1 unit. Maybe i'll take a few pics of it tonight if i get home at a decent hour.
hmm good tutorial roman i will have to be replacing my pass side motor soon starting to crap out on me as of late...it still works sometimes but i have to hi the button a couple times
So i my motor takes a crap, I have to buy an entire new set of mirrors to replace it?? Thats crap!
nice and smooth tutorial GOOSEY, great job
its the colddddd, nothing you can do about it. But my drivers side motor broke so my pass side might be for sale soon :)
oh ok just wondering... nice tutorial by the way very detailedOriginally Posted by GOOSEY2099
Do you by any chance have the wiring diagram because trigg forgot to send me one.
the 3 wires go to the stock wiring and the folding wire has to go to a 12v power source
Please search the forum for the wiring diagram. Cali posted it here at one point.
Duh, why didn't I think of that. Found it, thank you.
https://thegalantcenter.net/forum/vi...ht=jdm+mirrors
Moving to Moderators section temporarily due to an adsense warning related to the missing images
