Thread: HOW TO: Disassemble JDM Power Folding Mirrors for the 8G
Showing results 1 to 19 of 19
    DISCLAIMER: If you break your mirrors, it’s on you! I take no responsibility for anyone’s actions and the results of your own doing.
    Tools you'll need
    Remove the rubber gasket
    Remove the screw holding the metal clip thats holding the wire
    Cut off / remove the plastic connector
    Uscrew the 3 bottom screws. NOTE: These are threadlocked screws so you have to use a High-Torque Electric Screwdriver to remove them
    Push the top of the lense up by hand
    Insert a flat head screw driver between the white braket and the lense then slowly pry the lense up
    Then with fingers pull the lense out of there
    Remove all the screws marked with a red circle using a phillips screw driver NOTE: DO NOT REMOVE THE CENTER SCREW
    Move the attached assembly aside, do not unplug
    Remove the other 2 screws
    Carefully using a flat head screw driver pry the little tab on the bottom corner and remove the bottom cover of the mirror
    Remove screw to release the motor
    Remove the Last Screw
    Done!
    11-13-2007
    -OKC-
    3,970
    Great tutorial bro.
    TGC Regular
    04-11-2007
    Montreal, QC
    607
    Sorry, I don't get it, whats the point of taking it apart? Do you need to take it apart before putting them on the 8g or something?
    Also you should be like the other threads... and put a disclaimer for not being liable for damages.
    'o4 Acura TL: Dynamic ;; AEM | P2R | Falken
    Sound.Vision.Soul // Drive.Drift.Dream
    Experienced TGC Member
    05-25-2006
    New York City
    1,028
    Quote Originally Posted by komodo
    It is because his motors went bad so he swapped them in so he didn't have to repaint the mirrors.
    P>S> I told you it can be done roman
    2000 Galant ES = Daily Driver
    TGC Regular
    04-11-2007
    Montreal, QC
    607
    Quote Originally Posted by Sleepervr-4
    Ohh I see. Makes alot more sense now. Thanks.
    if you want to take them apart this is how. Otherwise don't. Angel is correct, one of my motors took a shit on me awhile back and i'm finally replacing it.
    08-08-2004
    Las Vegas
    2,099
    what does the motor look like? is it just one of those round or rectangle ones like at radioshack?
    nope, nothing like it. its all 1 unit. Maybe i'll take a few pics of it tonight if i get home at a decent hour.
    04-10-2005
    NYC
    3,695
    hmm good tutorial roman i will have to be replacing my pass side motor soon starting to crap out on me as of late...it still works sometimes but i have to hi the button a couple times
    11-13-2007
    -OKC-
    3,970
    So i my motor takes a crap, I have to buy an entire new set of mirrors to replace it?? Thats crap!
    04-10-2005
    NYC
    3,695
    apparently lol
    TGC Regular djflex167's Avatar
    07-21-2007
    Manhattan, New York
    709
    nice and smooth tutorial GOOSEY, great job
    its the colddddd, nothing you can do about it. But my drivers side motor broke so my pass side might be for sale soon :)
    08-08-2004
    Las Vegas
    2,099
    Quote Originally Posted by GOOSEY2099
    oh ok just wondering... nice tutorial by the way very detailed
  15. #15
    11-13-2007
    -OKC-
    3,970
    Do you by any chance have the wiring diagram because trigg forgot to send me one.
  16. #16
    04-10-2005
    NYC
    3,695
    the 3 wires go to the stock wiring and the folding wire has to go to a 12v power source
  17. #17
    Please search the forum for the wiring diagram. Cali posted it here at one point.
  18. #18
    11-13-2007
    -OKC-
    3,970
    Duh, why didn't I think of that. Found it, thank you.
    https://thegalantcenter.net/forum/vi...ht=jdm+mirrors
  19. #19
    Moving to Moderators section temporarily due to an adsense warning related to the missing images
Tags for this Thread
