if its overspray from like spraypainting you can use a claybar on the car and it should come off. The only other thing you can try that I know of is "De-natured Alcohol". From what Ive seen it doesnt remove the clearcoat or fade the paint. You can buy it at ur local hardware store. Ive used it to remove scuff marks on my paint. Works pretty good. :)
But if its a can of paint he ranover, Im not sure if it will work but its worth a shot.
