Front sway bar
Does anyone know if a front sway bar off a v6 2000 galant would fit
an I4 of the same year????????
Experienced TGC Member
if it's the strut bar your talking about then yes. if there is a sway bar up front for the V6 i am sure it would
C.J. Cameron
RETIRED TUNER!!!!
![](http://perrinperformance.com/images/logo.jpg)
"Keeping it Simple"
whats up laz,, na im talking about the sway bar under the car
What am I thinking yeah man it will fit. Check out www.dthreedesigns.com If you haven't already found one. There is the whole underbody Stiff kit for the Galants V6 and I4 applications are the same. I wasn't sure what you were refering to
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
if you have a DE then you will need the mounts for the anti-sway bar from a ES or better model.
as for the suspension techniques front anti-sway bar, don't get it... it is too stiff and you will lift you inside front tire on hard cornering... the rear one is good enuff if you want to upgrade to that (but u will have to do some modifications to mount it since it is made for the 00+ eclipse).
Thanks reelax,,, im glad to see you know your stuff
