When does it do this? When the car is at idle in Park? Or at idle while stopped at a light? Does it do this when youre running the defroster or air conditioner?
tne car accelarates up to 2000rpm"sand decreaes by it self. it does it
went it feels like it,i thougth it was the aftermarket intake so i put the
stock intake back and it still does it. what can it be?:smt102
Sounds like your IAC (Idle air control) valve has crapped out. It constantly idles up and down on idle right?
Kinda sounds like that problem I had with the TPS in my other car
~Lady Driven~
if you recently unplugged your battery that could be it, give your car some time to re-learn everything it needs to.
check the throttle cable as well & lube it a bit
I have had two cars in the past that have done that while in park and it was a vaccum leak. They were both automatics.
Im thinking IAC, but let me know wassup.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
