Thread: run1206's turbo build: Parts complete
Page 7 of 13 FirstFirst ... 34567891011 ... LastLast
Showing results 121 to 140 of 241
  1. #121
    08-04-2003
    NY
    4,344
    ok so I got the pics....
    the pan was drilled, mounting flange was checked/straightened so it was perfectly flat, the entire pan was glass bead blasted, hot tanked and painted flat black. The fitting is a -10AN aluminum fitting that was turned down on lathe to fit perfectly. I have to say this pan came out extremely good, I would honestly never put another pan on a motor without having it blasted, hot tanked and painted.
    99' Galant ES
    4G64/63T
    AEM EMS
  2. #122
    Experienced TGC Member run1206's Avatar
    08-15-2006
    Perth Amboy, NJ
    1,558
    wow, that looks really clean. :shock: :D
    did you get my payment yet, cuz i'm not seeing the deduction from my bank account :?
    run1206's Rear Disc Tutorial
  3. #123
    08-04-2003
    NY
    4,344
    it said I had it, but it didnt clear yet to my account, it says in-process.
    99' Galant ES
    4G64/63T
    AEM EMS
  4. #124
    08-08-2004
    Las Vegas
    2,098
    that does look really good hot tanking dirty parts is the best lol
  5. #125
    08-15-2006
    Perth Amboy, NJ
    1,558
    the oil fittings and the oil pan are in.
    a little test with the -10AN fitting, went in pretty well. :D
    the only parts i need are the gaskets and the DP flange, although i'm starting to question whether i need an oil catch can or not. :?
    about the DP flange, don't know if i should get the:
    two bolt flange
    or the
    three bolt flange
    (i'm assuming the two bolt one cuz that's what i had to work with when doing my cat-back install)
  6. #126
    looking good so far drew
    What did u buy for feed and return lines??? Pics???
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  7. #127
    08-15-2006
    Perth Amboy, NJ
    1,558
    i got SS lines from GOOSEY2099 for the oil(-4AN for feed, -10AN for return), and standard black water lines
  8. #128
    04-10-2005
    NYC
    3,695
    a catch can you can always add later but if you want to do it now they are only like $30 i wouldnt say it was really neccisary though
  9. #129
    08-04-2003
    NY
    4,344
    I would recommend getting a catch can sooner than later. I dont know how many miles are on your old motor, but if its anywhere passed 80k, I would think that there would be substantially enough blow by to warrany a catch can.
    99' Galant ES
    4G64/63T
    AEM EMS
  10. #130
    Quote Originally Posted by run1206 View Post
    how long are they ?? the reason im asking cuz i read on club3g that if u r gonna run the feed from the oil filter like u r gonna do a 24" line is either short or about right
    '95 Kawasaki ZX9R
  11. #131
    08-15-2006
    Perth Amboy, NJ
    1,558
    and the papers are 11" each so it looks like around 3 feet.
  12. #132
    Hey Drew, check my post over on GF. Hope that helps clear things up.
    222whp/250wtq
  13. #133
  14. #134
    Proto
  15. #135
    hey drew how much did u spend so far on this ??
    '95 Kawasaki ZX9R
  16. #136
    08-15-2006
    Perth Amboy, NJ
    1,558
    about 1300, rough estimate so far...
    the only thing i need left is the gaskets and maybe the oil catch can.
  17. #137
    any updates
    '95 Kawasaki ZX9R
  18. #138
    Hey Drew did you talk to Kory yet? If not i'll give him a call tomorrow.
    222whp/250wtq
  19. #139
    08-15-2006
    Perth Amboy, NJ
    1,558
    spdracr: oil feed line just came in today, i'll pick that up from home on friday.
    laxin: i didn't get the chance to call him, been studying all day long for my midterms for tomorrow. if you could call him, that'd be great, thanks much :) let me know if he's available anytime next week.
    edit: last few parts of my install is in!!
    Part 2: Install
    Probably next week (my "spring break"), will post up lots of pics; hopefully get a tutorial going :D
    more to come soon ;)
  20. #140
    08-15-2006
    Perth Amboy, NJ
    1,558
    k, update.
    stuck at a certain point. we were only able to get the WRX injectors in but there's a fuel leak between the fitting and the rail. so i wanna get a specific fitting for the rail. i'm wondering whether to get
    90-94 -6AN fitting
    http://www.extremepsi.com/store/cust...at=1559&page=1
    or 95-99 -6AN fitting
    don't know which one would fit on our rails, i'm assuming the second but not quite sure. gonna check autozone in a few minutes to see what i can find out
