Can you explain when this popping noise occurs?
last year i had my driver front control arm replace cuz it was popping on bumps and stuff and that fixed the problem. now its been make that sound again and the ice bumps under the snow does not help the popping sound. does the control arm need to be replaced again? ugh this sux ballz
7G giving to brother: EATSLEEPJDM
Team ID08055- http://www.youtube.com/watch?v=xWgDB7VGTv0
siniGANG represent!
on bumps and railroad tracks and on gravel pathways
siniGANG represent!
check the sway bar bushings. You cant figure out untill get them unbolted - both sides and shake the bar. Mine had a huge play
Replace your upper strut plate bushings. Mine were worn once and they made a "popping" noise on pretty much any bump.
Fix your sig size first then ask questions.
Hmmmm...
