Fill the radiator until you can see the fluid at the top, and the reservoir should have a fill line on it.
Hey guys, I have an extremely slow coolant leak on my 4 cyl 8g. I filled it last march and a minor overheating problem went away. The car is starting to run warm at lights and such again and I bought antifreeze again. My question is how much do I fill it up to in the resevoir and should I add some into the radiator? Thanks in advance and I used to search but to no avail.
Make sure your engine is cold because antifreeze expands when heated. You don't want to waste more antifreeze.
Ok so when it cools down I will add it straight to the radiator. The owners manual said when the engine is cool the resevoir should be between the full and fill line. Very vague, so I guess fill it somewhere in between and the radiator and I should be good?
if your coolant isn't premixed, at least have the proper water to coolant ratio
I put in premixed prestone antifreeze. I haven't even noticed any puddles or drips whether or not the car is idling after being used or its cold. Its weird, it took a year for it to become an issue again.
Check to see where it is leaking from. Look at all the hoses and try and see if there is a greenish yellow substance on them. If not maybe you have bubbles in the coolant system. I had the same problem. Open up your radiator cap when it's cold so it doesn't blow antifreeze on you. Then blast the AC and just wait a while, antifreeze should start coming out of the radiator if you do you bubbles in there. I don't remember if you have t be in drive or neutral though so I'm not sure.
