Theres a tutorial on here somewhere on how to remove it to change lights I believe... But other than all the screws that hold it down on top, Remove the grills and theres two more there..Can't remember if there are more..
OK totally noob, dont laugh too hard. Can someone please tell me where the bolts are to remove the 7G nose panel, I think the american name for it is different. I had a go the other day but couldnt find them, well only the 4 that are easily seen at the top. Does it jus slide off or sumit? I did a search but couldnt find any threads on this, so it must be easy.
Thanks
Kenan
you need to take off the bumper and there are two that share with the fender. the other two are throught the grills/hood latch area
On mine there was 3 (or 4) on top of each headlight.
2 behind each headlight,
(you need to remove the center screw for the headlights to get to these)
And 2 on the bracket that holds the lock for the hood
(these are on the left side)
After removing these bolts, the nose panel is free.
PS: I`ve got the european model,
don`t know if it is the same...
Great that helps alot thanks all
