if your factory struts aren't blown Id suggest the Factory Struts with the Progress Springs. I had them with 18" rims and there wasn't any problem. if you need struts thought then you'll have to find a cheap set. the only option I have seen that's really worth the money are the KYB AGX Struts anything else would be uncivilized. As far as coilovers. don't go with anything cheap. take it from me. Ground Controls are the best way to go. I know all the things I am suggesting are a bit costly but trust me you don't want to buy something then have to turn around and buy what you should have bought the 1st time.
