try hitting the key pad twice for the unlock feature and all of the doors will unlock. the unlock button of course
This is brand new issue. It was working just fine up till about a week ago. I used to be able to unlock all the doors to the g with the key in the driver side but now I always have to hit the button on the door panel to unlock all the doors. The key will lock all the doors fine but just won't unlock them. Anyone know what the problem could be?
If you turn the key twice it should open all the doors
behind the lock cylinder theres a sensor that attaches to it that allows you to do that...chances are it fell off the cylinder
yep...you'd take it off and pull the clear plastic weather thingy on the top left side and if thats your issue you'd see like a cap connected to wiring hanging and you snap it back on to the cylinder
