if anyone can actually find where to buy the 4point underbraces for the 7g, ralliart, cusco, doesn't matter, i will personally suck them off
Which item? the JDM strut bar?
seriously
Does the 2g one fit?
yes
Only ones I found were 2 point. There is a 4 point for the Evo though.
there's a 4point made by ralliart, i know this for a fact, the cusco one hasn't been confirmed.
The ralliart one isn't in production anymore and was never marketed over here so it would be by the grace of god that you could find one.
222whp/250wtq
In the past I've had 2 JDM sources scour
junkyards and ralliart suppliers but no luck.
dohcstunr has the 4point ralliart in red....IT IS POSSIBLE!!!
Agreed. There's more out there somewhere.
...somewhere. :neutral:
Sirs I'm using the 8g jdm strutbar how can I correct the hood because the strutbar created a little hump outside and a bit noticeable . I already adjusted the rubbers in front and the hood sits a bit higher. I want to return it to original without the hump. is that posiible? what about hammering a bit on the inside of the hood? btw mine is sohc.thanks!
Jump on the strut bar a bit (assuming you have some weight) and it will bend it just slightly and allow the hood to close tight.
welcome to the kia forums![]()
i put blue painters tape on the strut bar sticky side up and let it stick to the skeleton. then i used the dremel to cut it away. i will take pics of it tomorrow.
