try with another code reader?
My service engine soon light came on, so I took it to my mechanic. However, the scanner didn't pick up any errors, so he turned the light off. Drive it today for 80 miles & the light went off again. Since it didn't give off a code last time, I have no idea what it could be.
My mechanic said it might be the Bank 1 catalytic converter off the manifold, the only one left I didn't change. I checked the gas cap & it looked fine. But there's no codes being read. I'll have to check Tuesday to see if there's a code this time.
Same thing's happening to mine. Light came on around 137k miles and had some weird stuttering problems, then went back to normal, then came back on, and now it's just random. When I took my car to get inspected/tires/etc the other day the light just happened to be off, since it keeps randomly coming on. I have no idea what it's for.
The only thing that ever actually happened performance-wise was when it came on the first time. It felt like it couldn't find 1st and 2nd gear (though I have no idea if/why the check engine light would come on for a transmission problem). At the beginning of those gears it felt like it slipped, and the delay between me pushing the pedal and something happening was long. It happened for about a day or two but then it went away. It's been over 1000 miles since that happened and nothing seems wrong...so I have no idea what it was.
Maybe this helps you a bit. Maybe Mitsu made it so the light comes on when you should be taking it in for a check-up (a certain mileage or something)? No idea, but my car's running fine and the light still comes on sometimes.
You guys should stop ignoring the SES light, it comes on for a reason. Go get it read at a good shop (not one that is just guessing), and have the problem fixed. Codes can also be pulled even if the light is not on. Or you could buy a reader yourself under $100, it's a good investment.
And no, there's no such thing as "mitsu made it so..." And yes, it could be your transmission on it's way out. But you'll never know it until you read the codes or your trans just dies one day...
Bottom line is: have the codes read first. Or deal with the consequences.
The light just went off today by itself, so I'll see if it goes back on later this week.
run1206's Rear Disc Tutorial
same here, light goes on and off
i noticed on hotter days, it goes off
mechanic said its emissions related, probably will fix next month
