maybe you broke or bent the clutch fork, you know the one that engages the thow out bearing to the pressure plate. maybe the throw out bearing is no good. make sure there isnt fluid leaking from the clutch line where the two hard lines meet the flex line on top of the tranny. How does you pedal pressure feel? Does it feel like it did before it stopped working correctly?
