And the point of this thred is????
I decide to weigh one of my GTZ 6 spoke wheels yesterday after inspecting it.
It ended up weighing 37.0 LBS.
The Goodyear LS 205/55/16 weight is 19.0lbs brand new and I have half wear. I'm guessing the rims weigh somewhere around 19lbs each accounting for 1lb of weigh loss from tread wear.
It is good info and I can be an ass all I want.
I never said the info was bad, did I?? I just don't see the performance here?? Stop assuming.
http://www.the-welters.com/racing/rotational.xls
This is gives an estimation on rotational effects on a wheel. I've been looking for aftermarket wheels for my car which we know the lack of torque these cars stock/NA directly affects the acceleration. Then when you think about the added stresses to the suspension and brakes. Typical 17" tires that are right fitment for our cars can range from 21-24 lbs a piece and decent rim is going to weigh at least 20lbs unless your willing to pay big $ for forge wheels. Light cast wheels bend too easily.
Weight saving
Reducing un-sprung mass (Wheels, discs etc) has a far greater performance benefit than reducing sprung mass (bodywork). In racing, some designers use a factor of eight. For example, saving 1kg on a wheel weight gives the same performance gain as saving 8kg of sprung weight. This is due to the following benefits :
http://www.dymag.com/Mototcycle_Wheel_Technical.html
lol people quit getting your panties in a bunch. And yeah this is good info, I wondered about this too with stock steelies and aftermarket rims when I was trying to figure out how much and if my 18"s would slow me down.
This is good stuff, I'm curious, anybody know the weight of Eclipse GTS wheels, I'm running those on my car right now.
There seems to be a lot of "asses" on this website since i came back lol
Back in the Family!!
my ralliart/eclipse 18" wheels/tires are like 55lbs.
the stearing wheel is soooo heavy.
