Jdm Sidemarkers
Hey guys I Just got set of the clear ones which I wanna put in...I was wondering anyone had a template or a pic of there fender after the cut?....also just to make sure I just wanna tap them to turn signals so I'd just tap into the thick green wire correct?
yes you do tap them in your stock signals, theres no template just have to measure, make sure to tape around the cutting area so you dont mess up the paint too...i will try to check how mine are wired up i know i did a few things since i also have turns w/ the jdm fogs
yea I was just gonna wire them up with tap n squeeze connectors and call it day...I'm drawing up template now I just wanna see generally how it should look lol
no your better off soldering it i had problems with the wire taps and eventually had to redo it
Member
becareful when drilling the holes in your fenders cuz there is a section of wiring harness behind each fender and when i drilled the one on the driver side i hit some of the wires. I didnt even notice till i got in the car and it wouldnt start. The check engine light wasnt comin on and the car would turn over but not start and one of the fuses under the hood blew.
