Thread: Infinity Kappa 60.9CS installation
Showing results 1 to 14 of 14
    New Member
    12-08-2006
    Prospect Heights, IL
    79
    I just bought Infinity Kappa 60.9CS component speakers (http://tinyurl.com/6sy7b9). The question is: can I install them using my original Infinity amp and wires (2001 GTZ) and skip crossover that comes with the new speakers ? Right now I have Pioneer DEH-P690UB head unit connected to the factory amp using MITAH adapter and it plays fine so I think that crossover is built into amp not head unit. And another: will these new tweeters fit into factory place without any modifications ?
    Experienced TGC Member Dominicano's Avatar
    07-31-2002
    Fort Worth, TX
    1,418
    if the speaker is an oversized 6.5 then yes it will fit, but if its a regular 6.5 you will need to get an extender ring or something of that sort.
    New Member
    12-08-2006
    79
    These speakers come with 6.5" and 6.75" mounting spots so that's not a problem. My question was about crossover and tweeters.
    Experienced TGC Member ZigenScarface's Avatar
    08-04-2004
    Westchester NY
    1,332
    you need to do full rewire..
    08-04-2004
    Westchester NY
    1,332
    full rewire and use what comes with the speakers
    Experienced TGC Member jimmy_o2's Avatar
    09-25-2006
    Central, Cali
    1,145
    ^yep from am to speaker
    03 I4
    it would be highly advised at least. for best quality. GL with it man. post pics of install if possible.
    08-04-2004
    Westchester NY
    1,332
    not even best quality but so you dont blow the speakers... on another note if your doing kappa series u should amp it aftermarketly regardless
    Just did a Warranty exchange on my 4 year old Kappa 60.5cs and there gonna send me the Kappa 60.9CS. The old Kappa came with mounts. I did a full rewire. I didnt use the OEM amp. I have them runnig with a MTX 4 channal amp with a Pioneer radio... Hope that helps. I put up some pics as soon as i get them...
    New Member
    12-08-2006
    79
    Can I use factory wires ? So I could just connect crossover that comes with the speakers to factory amp and then factory wires to that crossover.
    New Member
    12-08-2006
    79
    After reading club3g forums I found that factory speakers are 2 ohms, same as those Kappa's that I bought. So I think that factory amp should provide enough power for new speakers and not to blown them. So I will try install new speakers using factory wires and built in crossover and check how it sounds. I will let you know on Saturday.
    08-04-2004
    Westchester NY
    1,332
    im telling you not to do it but u must know better then me about it...!
    i guess everyone on club3g are MECP certified
    New Member
    12-08-2006
    79
    I'm not saying that I know better. I'm just saying if my new speakers have the same impedance as stock ones and they can handle up to 90W RMS (stock amp is a way lower for sure) I won't blown new speakers. Even if something will blown it should be stock amp not speakers or head unit. Am I right ?
    New Member
    12-08-2006
    79
    OK installation is partially done. I have replaced stock low/mid speakers with these kappa's using factory wires and amp. They are playing super fine and nothing was blown. The problem is factory tweeter cover. Tweeters that came with kappa's wouldn't fit inside :/. Anybody know if I can get some custom made bigger tweeter cover for 8G ? They are 2" in diameter and 1" depth. If I won't find anything I will probably get stock corner cover for 8G without tweeter pod and mount kappa's on it.
