NEWBIE
Will they fit?
Ok, sorry to bother you guys again with wheel questions, but I have had some change in plans.
I'm looking at some rims that are 19x8.5's with +45 offset. . . just wanted to know for sure if they're gonna fit before I order them, Thanks again
once again, I am installing the tein springs and KYB struts, if it makes a difference on wether they're gonna fit?
i think your ok on the outside but may rub on the inside.
NEWBIE
what about the same size, in a +38 offset. . . . which ones better?
NEWBIE
and is a 235/35/19 gonna fit or should I stay with a 225/35/19?
I have 19x8" +40mm offset with 235/35-19s.
A lot of members have used 19x8.5" wheels with that type of offset. But honestly its rather wide. I would suggest a 19x8" with 235/35-19s. But if possible test fit the combo that you want on your car, thats the only way you'd actually know it fits.
Another note: I rubbed in the rear even at stock height, just slightly. You will DEFINITELY need to roll the fenders no matter if you have a +38 or +45mm offset wheel. And lowering the vehicle without rolling the fenders is a sure fire way to rub. You shouldn't need much rolling though, but most importantly make sure you test fit JUST THE WHEEL first, then the wheel and tire.
i have 18x8.5 +38 with 225/40/18. rears are cut and i still rub in the front. just a bit.
i also hit something on full lock when turning the streering wheel. still gotta figure it out.
