Thread: **UPDATE** 10/04/03 Parts list for drum to disc conversion
Page 1 of 2 12 LastLast
Showing results 1 to 20 of 27
    Faction
    Here are the links on imagestation to the actual size of the parts list!!!! Sorry for the wait, but i wasn't the one who did the actual swap.
    http://www.imagestation.com/album/pictures...l?id=4290362615
    IF you don't have an imagestation account, you can't view the pictures
    here's a good thread to read about it click and this
    Senior TGC Member
    07-31-2002
    Sugar Land, Texas, United States
    2,175
    Since I already have disc brakes I wanted to do the 2 piston conversion from the older GTs. Might help with the weak braking. Or I might as well look for a 4 piston system that fits in a 16 inch wheel...good luck to me.
    Faction
    <div class='quotetop'>QUOTE(ToigerFoighter)</div><div class='quotemain'>Since I already have disc brakes I wanted to do the 2 piston conversion from the older GTs. Might help with the weak braking. Or I might as well look for a 4 piston system that fits in a 16 inch wheel...good luck to me.</div>
    yeah it will be good to get the 2000 GT V6 calipers because they are 2 pitson calipers, i bought mine new from the dealer
    Experienced TGC Member Lazarus's Avatar
    07-31-2002
    Jacksonville Florida
    1,409
    THe List was to small to read. HOw much did everything come to for the conversion also do you have a bigger List.
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    Faction
    i dont know how to post pics, but i spent approximately 500 bucks, ill try to get a bigger picture
    miragal
    Do you change the rotors too or just the calipers? :?:
    Faction
    i changed the rotors to cross drilled
    07-31-2002
    1,409
    So you did disc to drum conversion for 500 in parts. that's not bad. Please see if you could get a copy of that list
    C.J. Cameron
    RETIRED TUNER!!!!
    "Keeping it Simple"
    Xska55
    Did you do the conversion yourself,,,how was it, what was the hardest part
    Faction
    hardest part was getting my drums off, maybe my ADD got in the way. and i broke my braided lines. its simple
    Faction
    Faction
    i would like a moderator to please delete this post and/or lock it! THANK YOU!!
    akiraflux
    can anybody give me a link to a conversion faq or somethin? i've been searchin everywhere
    cdaw2001ES
    no doubt, the pics are way to small to read
  15. #15
    I tried zoomin in on them, and all i saw were blurry pixels. Is there anyone else that has the info on this?
  16. #16
    What parts?
    On this post it really doesn't show the parts u can't see anything in that lil picture u posted. So what parts did u use? And u didn't have to change the axle or anything else? Thanks.
    2002 Galant ES - I4, Viynl Interior by P
    Pioneer AVH-P5700 DVD, RF P4004, RF P8002, 2-Infinity 12" Perfect 12.1DV Subs
    Lightning Audio Digital Capacitor
    Infinity Speakers,GTZ Spoiler, Ractive E-brake, Chrome Door Handles, CF Armrest
    Freedom Design Strut Bar, Cleared Corners
    KUMHO 711 Tires, CF Interior Trim
  17. #17
    Faction
    oh man, this post is old and i never made that post. well im going to try and see if imagestation still has the REAL picture for you guys, just really busy to check it out.
  18. #18
    Gir
    not to rain on anyone's parade, but please read this article when you consider 500 dollars on a brake upgrade.
    http://www.stoptech.com/whitepapers/rear_b...etter120601.htm
  19. #19
    cdaw2001ES
    For some - it's simply a visual issue. Sure AEM or whoever makes nifty shiny thinkgs to cover your drums, 4 wheel disc look better
  20. #20
    leadfoot
    soory but i can read the parts list what does it include?
