If the gauges light up direct from the battery, then they're OK. Check the wiring to the hot side of the dimmer switch. If that's not connected securely your gauges won't light up. Obviously the dimmer is plugged in since it dims your AC lights. If you've got a crimp and squeeze connector on there it's probably bad. Cut it off and solder.
