my car when its not warmed up makes lots of noise when put in reverse. I know a couple members here whose cars do that. Its common.
To Day When I was Going To Bring My Son To School I Hear A Sound When i Put The Car in Reverse Anybody Tell Me If Something Going Bad in The Tranny Or Motor And It Is Doing It
Need more details!!! i cant tell you what it is when you just say a noise what dose it sound like.?
1996 galant s
ok, its not something to be worried about unless you get lots of vibration along with the noise. what you are hearing is the gears actually meshing. the reverse gears in alot of cars are not helical, meaning they are straight cut instead of being angled. this causes alot of noise while the gears are engaged and moving. all forward gears are helical to reduce the noise while traveling except in dog boxes and other types of racing transmissions. i could continue but im sure i answered your question.
Why Do All Your Words Start With Capital Letters?
xxl, did you even read my post?
no, he didn't like how he never reads other peoples's post on HIS other threads....
That sound is the just the gearing in reverse. How fast are you going backwards? I mean reverse always has a whirring noise....nothin out of the ordinary. Unless that aint what you are talking about
i wasnt on the gas at all but i let it warm up real good the other day it have not come back
Ok...taking a shot in the dark here. When you were backing up...did you just start the car?
Reason I am saying this is if you just started the motor first thing in the morning...its going to run higher RPM's till it reaches normal operating temps. Well IF you didn't give the motor a chance to warm up and its running at peak warm up and you suddenly put it in gear especially in a A/T car, the engine speed decreases significantly for a short time and enough to make the belts squeal. If you had a similar noise...then thats probably the problem.
Nuh it was like warm up for like 5 mins i would say
