Sorry for the crappy phone pics, but does anyone know what this kind of fitting is called?
It came with my Tial wastegate, and I am looking for another one - its a 1/8" pipe with hose barb on a banjo bolt.
Also, anyone know who carries this part?
yeah, its technically a banjo fitting, but its kinda unique to tial wasgates/bov's
Also drybear, just an fyi in case you didnt know, you only need two of those fittings for the wastegate if your running an electronic boost controller, if your running an MBC you only need one and you can just leave the fitting on top of the gate open or block it off with a plug, doesnt matter.
4G64/63T
AEM EMS
If you look around you might find better prices, but RRE has them.
Thanks for the replies.
That one I took a pic of is actually the one I didn't use for my Tial Wastegate (came with two of them) - I was actually hoping to pick up more to use for the vac lines on my vacuum manifold to try and save space.
why are you looking just for fittings that are swivel adjustable so you can angle them a certain way for the vacuum block? You can buy just regular 1/8" barb fittings from jegs, they sell straight, 45 degree and 90 degree and im sure they are alot cheaper than those tial ones.
4G64/63T
AEM EMS
Yeah, I thought they would cost more, but didn't think it would be that much more - the ports on the vac manifold are too close together to tighten a 90 degree elbow fitting or even a 45 degree fitting. I'll probably just go another route - thanks for the replies, though.
