Thread: Post a pic as your car sits now....
Page 431 of 1457 FirstFirst ... 3313814214274284294304314324334344354414815319311431 ... LastLast
Showing results 8,601 to 8,620 of 29136
  1. #8601
    TGC Regular
    12-14-2006
    New Zealand
    823
    Effin forums glitching makin me double post....
    1995 FTO - V6 Mivec 200hp
  2. #8602
    07-20-2003
    Orlando, FL
    3,168
    Quote Originally Posted by Goku View Post
    4-G: I don't think that rear diffuser you have there is going to work properly if at all, it's sitting too far back from the rear of the car. You'd need to graft one into the rear bumper for it to be effective.
    Its positioned near where it would be in a WRX STi...if anything a bit closer to the rear bumper actually.
    I may play around with it to move it somewhat closer to the rear...we'll see.
  3. #8603
    205/40/18
    shaved QP
    wheels are 18x8 +15 with an 8mm spacer
    max camber with ingalls camber kit
  4. #8604
    TGC Regular
    12-14-2006
    New Zealand
    823
    Quote Originally Posted by 4-G-rim View Post
    True, the the WRX is shaped differently in the rear, we had a bit of a discussion about this on Club VR-4. If you wanted to run it there and make it actually do something, you'd need to re shape the bumper slightly to gain a benefit from the downforce.
  5. #8605
    TGC Regular
    12-14-2006
    New Zealand
    823
    Quote Originally Posted by VIPtint View Post
    205/40/18
    shaved QP
    Damn thoes are some small tires for the width of the rims man, they must be streached out to fit ?
    Looks like you're going to have to flare out the rear guards.
  6. #8606
    07-20-2003
    Orlando, FL
    3,168
    I will see what I can do and see if I can reposition it. I don't want to hack the rear bumper though..so I will see. This is the type of obstacles when there isn't anything aftermarket for your vehicle.:(
  7. #8607
    theyre hardly stretched at all. but tire companies dont make 195's for 18's
    and it doesnt rub at all.
    the front rubs the inner platic liner at full turn. havent cut it down yet
  8. #8608
    facelift grille on
    and fixed the toe as much as i could on stock adjustments. its still crazy toe in though. gotta look for other ways to get it close to in spec. doesnt rub at all anymore.
    still dont know when im gonna paint it
    Man im lovin what youre doing. Im figuring out how to fit some 17x9's in my rear right now. Got some staggered SSR Scopes with SSR GP-0 face swapped and it looks like a real tight fit. imma have to find out what you did to make it happen. Im looking to put them on in january. For now I just picked up some 19 inch G35 wheels to hold me over til i figure out how those staggered 17's will fit in the rear.
  9. #8609
    looks like it'll work on an 8g with the vr4 rear bumper due to teh angle it creates when u have the extensions and everything on
  10. #8610
    Quote Originally Posted by dronesurfboards View Post
    with a 17x9 you can go as low as a +20 offset as long as you do what i did. which was shave the QP and max out the ingall camber kit. i bet your offsets arent that aggressive so they should fit fine. oh and run a 205/40 on that rear wheel
  11. #8611
    yeah i was gonna go max camber and stretch 205's. did you cut the fenders out? i test fitted them, and it looks like the lip might clear but i didnt know for sure since there were 255's on the wheel.
  12. #8612
    crap, just read the post again. time to use a dremel. lol!
  13. #8613
    as long as its not lower than a +20. whats the offset, you might clear with just a shave and not the camber kit.
  14. #8614
    they are +38 but i was gonna use spacers just to make sure it cleared the shocks.
  15. #8615
    youre fine, you can go up to a 15mm spacer if you want it super flush but you will need the camber kit. test it first. pull off the tire and the struts. bolt the wheels up and use a small jack to push the rim up to test fit them.
  16. #8616
    Yeah, my friend is gonna let me use his 15mm spacers, its just tough to see it work with those 255's on the wheel. I just have to adjust the camber kit and dump the car 2 more inches if i can.
  17. #8617
  18. #8618
    08-04-2003
    NY
    4,344
    too low
    hey where did you buy those sides
    99' Galant ES
    4G64/63T
    AEM EMS
  19. #8619
    dont remember but from somebody on here i think. couple years back
  20. #8620
    your rims are aweful....
    j/k
    Step Lips..
    FTW!
Tags for this Thread
