Except for the OD function, good that it fits :)
So this morning I went to the junkyard and saw the 7g automatic shifter and thought ,"hmm, that looks a lot better than mine!"
I ended up buying it for around $3
After taking off my 8g oem shifter (place it in L for maneuvering)
it looked like this VVVVVV
Now shave the top little triangle with a dremel
VVVVV
To make the top of the inner tubing fit the white plastic, you know need to shave the edges:
VVVVV
Test fit to make sure its somewhat snug, some freeplay is fine
VVVVV
Now I simply used a flashlight and aligned the bottom hole of the 7g shifter to the top hole of the 8g shifter column,
Honestly it is a little loose(it only has one screw holding it!) but im sure ill eventually take it off eventually and drill a hole lower and shave more off the top of the white plastic piece we shave earlier.
Final product;
Now i keep my fingers crossed and keep checking the junkyard for the oem silver trim pieces or paint them myself.
5-speed 6G72 w/ bolt-ons [sold]
'93 Nissan 240sx vert
Looks good. Nice pick up.
Tuned 2013 Evolution X GSR PB
Yeah i know but its whatever, now my interior looks more appealing to me now. Maybe i could wire it up to some tyte neons yo haha JK. My friend said i should write NO2 on it instead hahaha
maybe you can hook up your fogs to the O/D switch :)
nice work :)
that does look a hell of alot better might pick one up and try it.......wonder what other stock shifters would work??
that same proces can work with Any shift knob really. I think all Stock shifters look *yuk*. ya might as well use an aftermarket one while you're at it. I did that same exact thing last year with a Pilot, and then a Greddy shift knob.
last pic i took w/ pilot..
yea i have mine like that now its jst really loose.
did you ever end up hooking anything to that switch? that would be gangs if u did.
wow my 97 avenger es had same shifter!
Am I the only one that likes my stock shifter?
A+ for the work though..
^yeah jeff, I'm pretty sure you are
looks good but i made it so that i could use a long aftermarker manual shift nob. i did the same procedure though. great minds think alike. lol. i hated that big bulky piece of crap. in order to shift it i just push down on the whole nob. looks great though. good job
Looks 10x better than the stock shifter but I'm a bit worried about how secure it truly is.
