yes. they will fit.
Here are the spec for an 06 tsx rims
215/50-17
Wheels: 17x7, +55mm offset, 5x114.3mm (5x4.5") bolt pattern, 64.1mm centerbore
Will these fit my car?
thanks much!
yes. they will fit.
will there be enough clearance on the strut side?
thanks - platno
Yea they will fit and actually look good. There is a member on here with some TSX wheels on a 97,very clean!!!
thanks for the info, i'm going to pick up a set today...
just an FYI every1 the centerbore is a tab too small...
does anyone know what size g8 centerbores are???
it's literally shy 1/8" from the hub...
any suggestions??
too late
referencing to B19 I went out and picked up a set...
TSX = 64.1mm and our G8's = 67.1mm so not too big of a difference...
I'll probably get a shop to enlarge the centerbore by 3mm = .1181" so not too big of deal, I hope...
A 3mm overbore shouldn't alter the structural integrity of that wheel much of any significant amount.
www.gooichimotorsports.com
thanks for the confidence...logically that's what i'm thinking...i'll post some pictures once i'm done....
I put them on with a 1/8" gap today just to test...lowered the car back down and indeed they look nice...
I guess anything would look nice compared to the stock steelies ;)
the centerbore is too small on honda wheels, u will have to run a non hubcentric spacer, thats what i did when i had on ITR wheels and again with S2K wheels
thanks
finally found the pics! Owners name is David from Maryland..
^ Thats the guy I was talking about that was going to have that car at 4G performance for a 4G63 swap. That 7g is clean!
