that would look badass if it was slammed to the ground with the fenders cut and pulled with a bit of negative camber.
wheels are Sport Maxx
size is 15x8
offset is +15
tires are 205/50/15
these came off a miata so thats the reason for the crazy sizes. just test fitting so see what some slammage would benefit with these wheels on my daily
i need to treat the paint better on this car. it used to be perfect now it looks like a cheap respray.
Needs lowered, not slammed, with wider tires, 205's are kinda small.
www.gooichimotorsports.com
idk i dont put much money into it
it would probably break all the control arms and bushings if i tried turning it hard with the sticky falken azenis on it. all the bushings in the rear are rotted out. one day ill start modding it. my 8g isnt anywhere where i want it though
same brand and specs of my wheels but mine are 18's. they fit with slammed with a lot of camber. and i have spacers in the rear
thats a lot of cancer VIP
those wheels just don't look right on a 7th gen.
its weird, 7gs look better with rims without a lip. and 8gs look better with a lip. i guess its a square and round thing
would look nicer with a 185/55-15 or 195/55-15, stretched tire, and a little poke, and slammed.
lips go good on a 7G but you got to get a good spoke design. also if the offset was diffrent it would pull it in closer.
my next wheels are going to have a thicker lip in the rear than the fronts
Looks like an autox setup for the wheels. At least for HS class.
Light em up.
Slam it please!!!!!!!!!!!!
if i keep these wheels im going to definantly slam it and invest in a camber kit that will help me out
