Thread: Kicker Solo-Barics
Page 2 of 2 FirstFirst 12
Showing results 21 to 22 of 22
  1. #21
    unless i am missing something, this is a dual 4 ohm, correct? above someone asked if it is going to be run at 2 or 4 ohms. If you want full power handling for the sub it would be 2 or 8 ohms. you only get 4 ohms out of a DVC 4 ohm sub if you only use one coil, which will cut power handling in half since they rate DVC subs with both coils being used.
  2. #22
    TGC Regular youngin3's Avatar
    04-02-2008
    Dallas, Texas
    642
    If it is a Dual 4 ohms sub then he can run them in parallel and his sub will show 2ohms to the amp. Full power handling.
