Galant parts for the 7g
What's going on 7g'ers. I see alot of posts about eclipse parts being compatible with the galant. If so what what year eclipse is compatible with the 95 galant as far as performance parts are concerned. :?:
What you have to do is go to your local mitsu dealer, and find out what year the 4g64 engine was used in the eclipse. I did the same thing, and i believe it was the 1g eclipse but do not quote me on that, but just call the mitsu dealer to find out what year your engine was used then u can go find parts
2g spyders used 4g64s, but u dont want to use 2g spyder parts. you want to use 4g63 parts!
1g(turbo or nt) and 2g turbo heads are almost a bolt on
2g strut bars
1g(t or nt) and 2g turbo exhaust manifolds bolt on to our head
94-01 integra gsr cold air intakes fit if u cut 1 in or so off the short ram pipe
theres more, im just too tired to think :twisted:
thanks
Thanks for the info. I will check on it
