it should just fall out....
hmmm... try wedging a screwdriver in between the strut and where it bolts to and tap it with a hammer. see if you can pry it off.
It seriously only took me 20 mins to install my two rear coilovers after I figured out how to remove the bolt with an adjustable wrench. the right side took about 15 mins then the left side took about 5.
