My dealership told me that my car was abused just by looking at it. Dealerships can kiss my A$$. :twisted:
<div class='quotetop'>QUOTE(Phyxsius)</div><div class='quotemain'><div class='quotetop'>QUOTE(11B)</div><div class='quotemain'>
i've adjusted the throttle body cable in the past, so no warranty anymore :?</div>
You've gotta be kidding me...not even my dealership was that much of a prick. Mine was a little loose when I went in and they said I had adjusted it. Since there were no signs of wear on the screws on the plate they just accepted the fact that they jumped the gun. Course they got me on plenty other items...</div>
they havent told me that, i'm just assuming the worst
<div class='quotetop'>QUOTE(Prophet)</div><div class='quotemain'>My dealership told me that my car was abused just by looking at it. Â*Dealerships can kiss my A$$. :twisted:</div>
Oh yeah that's right...forgot all about that. Mitsubishi is even worse than when all of those M3 engines were dying and BMW kept denying that their amazing cars could possibly be flawed...but I'm proud of Toyota for attempting to appease the Sienna customers.
<span style='font-size:25pt;line-height:100%'>okay, this is some bullshit :!: :!: </span>
i'm on my way to get my hair cut, and i had to stop for gas. i fill up, get ready to pull off, and the damn car wont crank. this thing was completely dead. no lights no nothingi'm sitting at the pump for like 30 minutes, and not one person had cables, me included :oops:
i finally get this f**ker to start, and its the same thing from the beginning. it wont stay started. this time though, the oil light keeps coming on. so i'm double footing it so it stays on. i get to the barber shop, and since thers an autozone next door, i get the alternator tested.
the guy said that its not as accurate while its in the car, but its close enough. the results:
Alternator checked out good
Regulator: 14.12 Volts
Peak Amps: 75.2
i get done with my haircut, and i barely get to the house, and damn if it didnt die completely again. no lights, no nothing.
<span style='font-size:30pt;line-height:100%'>WTF??????</span>
this is gonna sound really simple but how about just poking around the engine bay. it could be something as simple as a loose wire or something?
<div class='quotetop'>QUOTE(PinoyESV6)</div><div class='quotemain'>this is gonna sound really simple but how about just poking around the engine bay. it could be something as simple as a loose wire or something?</div>
i did that the very first time. everything i know to check is nice and secure. i'm disgusted right now. its funny that you say that allan, cause my barber said the same thing. he was like you know when you take it to the dealer, theyre going to tell you something thats so simple. if thats going to be the case, why cant i figure it out
<div class='quotetop'>QUOTE(11B)</div><div class='quotemain'>why cant i figure it out</div>
Because...it's...*argh*...a...*can't stop it*...MITSUBISHI!!! Damn...I thought I could control myself a bit better than that![]()
if it was the battery, your car wouldn't be starting!
you know i went out this morning, and checked my oil before starting the car, and the level was right in the middle between the low and high hash marks. its weird though cause when i checked it the other day, it was closer to the high hash mark. and thats after sitting all night
because its the engine is cold
<div class='quotetop'>QUOTE(Faction_03)</div><div class='quotemain'>because its the engine is cold</div>
i know that :!: what i'm saying is that both times i checked it with the engine cold taht way i could get a more accurate reading
it just dawned on me today. is there a possiblility that my intake filter is very dirty to point its not getting the proper amount of air. i am using the filter that came with my injen intake, and i've had it going on 8 months. just curious
That might be a possiablity but I doubt it. I had mine for over a year and I just cleaned it last week for the first time. The K&N filter that comes with the Injen is supposed to be fine for 50,000 miles. In fact right on the K&N recharge kit it said that you might want to leave it dirty because it helps it in some way.Originally Posted by 11B
okay,i take the car to the dealer this morning, and was told that the oil pressure sensor switch was bad, and that the idle air control motor was failing. both were replaced, and it ran me $550
they noted on the invoice that everything was reset to specs and the throttle chamber was cleaned. damn this stuff is expensive. we will monitor during the week, and see how she holds up. driving home, i could feel a little better response than before, so hopefully thats a wrap
damn $550, thats deep, yo - - hope that solved the problem for ya, homie
Semper Fi'
I'm having the same problem and I'm pretty sure that I have to replace the idle air control or at least have it adjusted. do you remember if you had your air or defroster on during the times it would not stay on because it is only when those are on that mine dies.
i didnt have anything running. no air, no stereo, no lights. its all good now. bebt more than a few corners su=ince taking it to the shop. everything is good
