Mkay. gotcha thanks.
3g and the stratus trans are the same, difference between the 2 comes with the flywheel and clutch setups, if u use a stratus flywheel u have to use a stratus clutch, if u use a 3g flywheel u have to use a 3g clutch (i beleive this is for the v6 only)
the only difference i see in the cables is from the pictures ive seen the larger link is facing down on the eclipse and on this setup it faces up
I just posted 2 links to Sonata manual trannies in the FS forum
all parts come in tomorrow minus the clutch. i dont want my car sitting at my shop if this doesnt work out so i may just do it at home, but the lift i have there is definantly calling me
the one thing that has me stumped is the way the linkage for the shifter is mounted. where on the eclipse the larger of the two faces upward, on the sonata it faces down. it looks to me as they mount up the same but the direction they move may or may not be different. that is one thing i plan to find out. if all goes well this could be a great alternative to those that one to get rid of their slushbox and save some money at the same time. if it doesnt work the rumors will be put to rest. here are some pics of the tranny, i want some opinions on what you guys think of the setup.
i posted this on club3g and got this response
so today i hooked the shifter up to the tranny to see which gears did what in what position. as it turns out which cable does what is reversed from out platform. it will not work with the cabels in their normal position. with the cables swaped around after the mount on the tranny, the reverse gear was in the bottom right position. where its supposed to be. so it should work as long as the cables do not bind. i also need the piece that connects the fork that connects to the throw out bearing to the slave cylinder. does anyone know what this piece is called?
Hey I was seeing if theirs any progress in this swap and/or how it turned out? as I'm very interested in doing it myself.
if you use a custom steel braided clutch line to connect the hyundai slave to the mitsu master. it will work. also switch the shifter cables around which is cake and it will work. there are plenty of trannys where i got mine from if u need one
