What's up and Welcome to TGC
A keyless entry system is not a big task if you are comfortable taking out a few dash peices and messing with some wires.
I installed mine last summer as it was part of my auto-start system (a must for Alaska weather). I don't want to discourage you but I have to say the the keyless entry portion was by far the most difficult. The wires you will need to tap into for an aftermarket keyless sytem are amazingly difficult to get to. They are waaaay in the back near the firewall and up behind the dashboard. I had to take my driver's side seat out just to get to them comfortably. The wiring instructions should come with the unit so I'll leave that be.
I just want to give you a heads up on it, it's not easy, but not impoosible either. Give yourself a weekend to get it done.
Wes
