Yup, the resistor pack is in there. I actually just pulled the whole wiring harness back out and I'm going over it again. Jeff from Keydiver PMed me on DSMTuners and let me know that pin 13 does need to see voltage from the fuel pump and that I can just send the signal from the MPI relay. I tried a quick fix for that in the car but it didn't make a difference. I'm also still only seeing 2.8v at the TPS which I'm fairly certain should be seeing 5v. So I'm going over all the wires again, cleaning up a few areas and stuffing the harness back in again when I'm done.
