i was reading up on post about this, i think the guys were talking about using a 3G Eclipse ECU and flashing it, or use the Evo ECU. If you do end up using the 3G/EVO 8 ECU, you would need to change the wiring harness on our 8g to match it with the 3G/EVO 8 ecu. Assuming you are talking about our 8G galant. Though i'm not to sure why they ended up using the 3G ECu instead of our own ECU instead, and flash it that way. o_O maybe someone can chime in on bout this.
