out of curiosity...why use 64 cam gears instead of the 63 gears?
i have decided im going to do the 2g headswap, i have the head just need the 64 cam gears timing belt and headgasket and now i have everything to turbo the car but im holding off on that aspect for a bit.
now my plan is to do the headswap, new ecu, injectors and all that at the same time except the turbo and i was thinking it would be very wise just to go to a 2g harness instead of some repinning and rewiring.
i see no major issues with this and i just want to double check before i get a new harness
thanks
Chris
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
i was thinking about getting a new harness too, just seems to me like the only big pain in the ass is going to be running it to the engine bay, and i dont exactly know what connectors work and which ones will need to be changed, but the cool thing is if you go with a 2g harness and the plugs are different you can just swap them with the ones from the 7g harness.
That was my thought on it.
1996 galant s
kev i agree with you the 64 cam gears total to like 50 bucks and its worth having the correct marks
and mitch.. im pretty sure if we swap out the harness we will encounter little issues as all the connectors will be correct for the head etc.
also.. i have a 95 head and in the tutorial is says i have to use the 95-96 CAS.. this isnt the issue tho.. the issue is that i have a 98 ecu so the CAS is different and i wonder if i will encounter issues
2014 Lancer Evo GSR
and changing out the whole harness is more a pain than swapping some pins. your going to have to move alot more pins to make everything in the car work. you can't run biggger injectors on stock non boosted motor.
i would hold off and do it all at once. it's going to be cheaper and easier than going back and changing stuff
Just get adjustable gears. I got a set of AEM adjustable gears for $110 shipped on eGay a few years back :P
Chris, since you have a 96, you have the 4-pin ECU correct? If so, you just have to add one wire for the knock sensor(if you use one) and one or two for the power transistor. You have to move the 4 injector wires around and two or three more. Honestly swapping to the 2g harness is a LOT more work, you would have to rewire the fuse box.
Keep the Galant harness, follow JiPs ECU swap tutorial, be done in less then a day :P
As for the CAS, that I am not sure, you will have to do some searching on DSMTuners. I know there is a difference between a 1g and 2g CAS, but I was running a 98 GSX ECU and then a 95 EPROM ECU on a 1g CAS with no problems. I would assume the CAS signal is the same no matter what year 1g/2g. The only difference between a 1g and 2g CAS is that the 1g CAS is adjustable.
If you have a 96 or later 7G I would recommend just repinning the few wires like Seth said. 94-95 is a whole other bag of worms.
I would also like to add that the 1G CAS also house the crank sensor, where as the 2G has a standalone crank sensor like the 96-98 7g. Also the positioning of the 95 CAS is different in comparison to the 97-99 2g.
RIP
1995 7G 4G64 / 63T DOHC Turbo
Part Out Coming Soon
In search of 2G 3000GT VR4
Daily driving
Dat '08 Cobalt Coupe
Swapping Harnesses is easy, I pull mine out in 15 min. The issue here is addressed to the connectors after the ECu going to the dashboard and instrument cluster. If the wires are different then you may get short somewhere and fry the ECU. IDk if someone can verify if Eclipse and Galant have the same connectors after the ECU
ok so its easier to just repin the connectors alraight.. now the 95-96 CAS is completely different from the 97-99 as the 95-96 cams have a little cut out on them for the sensor.. my main issue is if the 97-99 ecu will work with the 95-96 ecu.. i looked over the headswap tutorial and saw nothing really about concerns of ecu years so who knows, i might be ok.
another question. i was planning on putting in the ecu, injectors, dohc, and the safc all at one time and run it like that for a short time before the turbo.. i know the ecu will compensate for the turbo but i can pull fuel so it doesnt flood or should i just do the headswap first by istelf and do the rest later
2014 Lancer Evo GSR
Like I said, Ive used a 95 and 98 ECU with the same CAS with no issues. If the 2ga CAS signal was different then the 2gb CAS signal, then one of those ECUs would not have worked with my 1g CAS.
With 450cc injectors and no turbo, I dont know how well the SAFC can pull back fuel trims. Just leave the injectors out of the equation until you are turbo. They take 15 minutes to wire in and arent required for the headswap.
I think it doesnt matter what year CAS youre gonna use - one is plastic, the other one has metal housing.... The difference in between 90-94 and 95-99. 90-94 has both crank and cam shaft sensors, and 95-99 has only cam sensor. The other difference is that 90-96 CAS cam signal has opposite polarity than 97-99 and if you want to use 90-96 you have to swap the injector pins 1 for 4 and 2 for 3 /cylinder wise/. All 95-99 ECU are compatible with minor mods, all are OBD2
If you want to run 2g ECU with 450cc w/o turbo youll need the MAFT. IDk if the SAFC can do it. As you said youll be running very rich and you low and some mid RPMs will be very shitty
Damn, Seth said it before me
i know they arent required for the head swap so i guess i will leave them out of the equation for now.. i will look more into it but if i can use the 95 head and CAS with the 97-99 ecu then i will be set
2014 Lancer Evo GSR
and thanks for the help guys
2014 Lancer Evo GSR
Yes the ECU will recognize the signal regardless. Although CAS positioning changed the ECU's did not. (minus eprom :P)
And yes the SAFC would perform the same task as the MAFT mko, although the SAFC is out of production if I'm not mistaken.
RIP
Daily driving
2014 Lancer Evo GSR
