you shouldn't have a problem getting into any gears, are you sure the shifter is not hitting the bottom?
just did the mod finally...the cutting was a bit of a pain only because the cutting wheel i use on the dremel is a little big to fit in like 2 spots...where it didnt get though i just finished with a razor knife...the whole mod took about 30 min...
first gear is a little harder to get into...aside from that as roman said the throw is much shorter and the shifter itself sits a lot lower...however, even with the armrest there it is still very accesable...
just for reference i have a v6 and have a b&m short shifter
it is just barely touching where it would go into first...i tried the washer but the stock bolt was just too short, going to the hardware store in a little bit and will fix that...
you NEED longer bolts
yep...i know, thats whats at the hardware store lmao
