Thread: Uneven Coilovers
Showing results 1 to 3 of 3
    Black Magic
    Uneven Coilovers
    Okay i go outside to lower my ride alittle bit more and i measeure that the front passenger side was already alittle lower than the front drivers side so i go and lower the front driver side to the height of the front passenger side. then i go and measure the front passenger side again and that dropped too. i only did this quick and i wanted to see what everyone had to say about this probably going to play with it more tomorrow.. WTF its wierd what do you guys think
    Mine were the same way at first...all I did was raised them all the way up and mark it off.......and just let it down on the same mark....
    hope this helps.....
    Black Magic
    thanks im gonna try that tomorrow
