water in headlight
I woke up this morning to find water inside my right passenger side headlight. What's up with that? It didn't even rain the nite before. How can I get rid of the water or will it dry out.
it might dry out, or it might not. If you want to fix it you can remove the headlight and drill a couple of 9/32 holes along the bottom to drain the water and the condensation. otherwise the water will stay and turn the lens yellow.
After you get the water out I recommend resealing your entire headlight with silicon to prevent furthur water from getting in.
