91 strut parts
I am trying to find a place to buy the rubber bumper or stop that fits over the top end of the strut shaft, also the dust boot that fits beneath this strut shaft bumper. Do I have to go to a dealer to get these parts? Any help is appreciated.
try www.car-part.com or go to a junk yard and ask around im sure they wouldnt mind selling em of a wreckd G
i wouldnt fool with used. on the upper strut mount, there is a bearing, and this bearing wears over time, especially if the dust cap is not there. dirt and moisture will get in there, and can even cause it to sieze. when worn, it will start clunking, also, the rubber part will wear, and cause changes in camber and castor when turning.
