update 8/15/09
man i would said the most difficult to do the swap is the under dash work
freaking dremel the 3 hole take me all day, but easier to do it with a proper tool.
my neck hurts ~_~
install all the pedals
took out the automatic shifting assembly(i took the whole console out and wash it too)
completely strip out my seats and wash it
was trying to take out the axle, but did have the 22mm for the lower ball joint
so i took the axle nuts tie rod apart
looking forward tml at least remove the auto tranny.
when i taking the bolts out of that triangle plate off the flex plate i found it shatter in two piece, basically i been driving with only 2 bolts' power! god bleed mistu auto tranny
