not meaning to sound rude but search and you will find your answer (you gotta take out the hvac controls and the bulbs are in the back of it, there is 2 of them and i think it is a 74)
So, I checked and replaced all bad the Fuses in the interior and engine bay fuse boxes, BUT the lights behind my ac controls still don't work.
Wondering if anyone has a tutorial to replace these lights...? Or advise to troubleshoot and fix this issue?
What bulbs are needed?? 74? 194?
thanks in advance.
I found the threads to take out the entire dash, including the center console and hvac controls. Is the a way to just take off the center console/hvac controls...?
look on the BOTTOM of the AC controls (pull the ac control out first obviously)...you'll see the plugs you need to pull to change the bulbs.
Cali: Sig 3/28/2011
you can take out just the center console by removing the radio bezel and all that but i done this a few weeks ago and getting the hvac out was kinda a pain
yeah it is. Its not hard, just a pain.
PinoyESV6 does led conversions to the hvac units too.. Might wanna look into that..
hmmmm.....speaking of havc controls... my little ring that goes around the nipple on the cool/heat control broke off. i thought my heater core was clogged when i switched over to heat and still had cool air blow... i have to take pliers to the hardline for the cool/heat control... how can i pull the whole line and replace it? i have stripped and searched my whole engine bay and cannot find the hardline
It doesn't go under the hood.. It stays under the dash.. You are talking about the cable right? It goes off the hvac control to the left on the drivers side. It's only about a foot long. You can see it if you look up and under your dash on the drivers side.
no wonder i couldnt find it. i will hit up auto zone and see if i can get one. or it might be a part only the dealer sells...?
