Originally Posted by
therev
Ill tell you where to wire it, i picture wont do justice. Behind the guage cluster is a small bolt holding the dashboard. Unbolt that and ground it right there and replace the bolt. Then run the power wire through the back into the back of the radio bezzel. Now remove the trim around your Auto shifter, it will pop right up. Then you will see the crack for the cigarette and the 12v bezel again pop that out. You will see two wires running into the 12v lighter, strip the Blue and white wire and tap the power wire (the red one) into there you are!
~Gabe
