Ok, so I took some pic's of the installed gs items and some mods that Ive done to the car.
Sohc head gasket (bottom) compared to the gs one (top).
Alarm I got from the j/y yet to install, waiting for the 2 remotes that I ordered to get here.
The real under dash harness I found in the trunk of my car, the other one I took pic's of is the front harness for the fogs.
As she sits now.
GS fogs installed but not wired yet.
You like my exaust pipe??? LOL, the burnt tip muffler fell off and ...well, I'm cheap so I got a 3" pipe from autozone and welded it on. Exaust allready has a magnaflow 3" res on it so it's got a mean, deep growl to it now, but not annoying and high pitched like most the ricers out there.
The gs rear disks installed. You can see where my suspension was sagging and rubbing the tire and cutting it to shreds. Had to grind the plates that the bumper bolts to down to get it to stop.
Just got done replacing the rockers and lifters to the ones out of my 97's 80,000 mile head.
Yes, the wastegate is wired open. Had to stop the turbo forom spooling out of control untill I get the piping and fmic installed.
GS rear sway bar installed.
Side view of the 3" pipe.
took a honda accord shift boot and modifyed it to fit the es auto shifter cover.
Used locktite superglue to fasten the boot to the cover. Ya I know, wierd way to get it to stay on but the locktite shit is strong as hell. Used it on my guage cluster 2 years ago and its still holding strong.
cut and shortened shifter and welded in a bolt for the shift knob.
Got a new cue ball and drilled a nd tapped it for the welded bolt on the shifter. Looks good huh? Feels great and the throw was reduced by maybe 10-15 percent. Going to cut and shorten a generick ebay short throw shifter to the same domensions after I get the trans changed to the gs one.
Fog switch installed. Remeber, that this car didnt come with power anything, Is all changed over to power everything even without the gs harnesses installed. Wasnt to hard , just had to change the harness under the dash to a 94-95 es one and the harness to the tails and the regulators and such. Took a day in total to get it changed over. Neighbors thought I was tweakin' for sure!! LMFAO.
My dual illuminite 6's. Everybody loves the glow of these speakers at night.
My 2 audiobahn subs (got the box with subs for 30 dollars) and 800 w volfenhagen amp is bolted under the rear deck. More to come as I get started on the GS engine swap. Got to go get the gs block and trans tomarrow. Will post pic's of the block when i get the chance. Might be looking for a good gs block if I cant hone out the surface rust on the cylender walls.
