Thread: Galant306m's turbo build
Page 23 of 65 FirstFirst ... 1319202122232425262733 ... LastLast
Showing results 441 to 460 of 1287
  1. #441
    As with any turbo'd car it has to be on point, im just going to really have to watch my fuel maps, and knock counts more. I leaning twards meth injection it looks like a sweet system and since i already have 750cc injectors i wont have to change them and i will not have to chang out all my fuel lines for larger ones for the added fuel consomption of e85.
    1996 galant s
  2. #442
    Experienced TGC Member
    12-27-2005
    Charleston SC
    1,520
    Meth injection is a great option. However. Its not an all the time deal. Im sure you can get a WOT switch for the pump or a push button. To every possible good thing there are 30 bad things that go along with it. To me that would be like a band aid fix. Youre injecting potentially harmfull chemicals into your combustion chamber. IDK if it would effect you guys as much it would us down here in SC with the salty atmosphere but i wouldnt trust it.
  3. #443
    12-17-2004
    Louisville, KY
    4,327
    ever seen the combustion chamber of a guy who runs alky or water injection? Its spotless and completely free of carbon deposits. Pretty amazing actually, but if you think about it, you are steam cleaning your combustion chamber on the regular. Having a spotless combustion chamber alone is a great way to ward off predetonation. As the carbon deposits do a great job of retaining heat between cycles and create hotspots for preignition.
    once i build a motor I plan to run about 30 or so psi daily driven on pump gas with the aid of meth injection.
  4. #444
    Its become my number one option right now. John you have a pm.
    1996 galant s
  5. #445
    12-27-2005
    Charleston SC
    1,520
    Im not saying this is a HORRIBLE option. Obviously its been proven. Im just not sure that id want to do that on my DD motor.
  6. #446
    yea, its a cheap option. my car isnt going to be a DD its just going to be a fun car. And the cool thing about the meth injection is every gas station has washer fluid so i can always have some.
    1996 galant s
  7. #447
    12-27-2005
    Charleston SC
    1,520
    just put a 20 gallon fish tank in the trunk with a sealed lid and run a suction hose from the meth pump to the tank in the trunk. Im sure that shit would last a long time. LOL
  8. #448
    RedGalant's :WUB: :WUB: ICEMAN99TURBO's Avatar
    01-24-2007
    Bad Axe, MI WELCOME 2 HICKVILLE!!
    481
    Quote Originally Posted by phizzalot View Post
    I believe those were 8g's which could be a little different.... I've been reading up on something like this and this fella dosen't look to have had a problem...
    http://www.extremeevolutions.com/4G64_buildup.htm
    It seems if he tunes it correctly and uses the appropriate fuel it will be ok...
    3G GTS Eclipes...
    Quote Originally Posted by Galant306m View Post
    Like Seth said I can run high compression and lower boost and make the same power. Im currently looking into somethings to make it work right and e85 is becoming an option, just have to look at some flow chats and figure out how much fuel i will need. So this may turn into me running two 255 walbro fuel pumps on 1200 cc injectors, which would allow me to run e85.
    105 octane is also an option but much more expensive in the long run, and i will not be able to drive the car on long trips because no one sells that high of octane, and since e85 is cheap its a good option I just need to educate myself on whats needed to run it.
    10.5:1 compression ratio isn't a really high number for a boost application you will start running into more problems when you are reaching 12:1 or higher is where i see people running into a lot of problems with knocking.
    I dunno man, I have always been taught if you want to boost, you run low compression or things will detonate. Inless you plan on running like 3/4 PSI. Again, what fun is boost if you can't feel it hold you in your seat? I awlasy saw that (for me) perfect bost was around 20/25 PSI.
    Guess I will see her when she is done. :)
  9. #449
    The reason you have to run a lower CR with a boosted car is because the air is already compressed, making it easier to ignite when it hits the cylinder, so lowering compression is the fix, with adding meth to the air, it becomes cooler because of the rapid evaporation levels of alcohol the air is then cooled making it more dense and with the combination of ethanol added to the air, you are thus able to run higher boost numbers with out worrying about knocking.
    that's basically what i have read all over the internet and how i understand running meth injection, and like john said its totally safe to run.
    1996 galant s
  10. #450
    01-24-2007
    481
    :agreed:
    But you better run one hello tank for your meth. When Ron had his SDS half ass working, we would take an hr trip and it would be 3/4s empty.... It was an GM windsheild washer tank.
  11. #451
    the kit that i am looking at has a 1 gallon tank, im also buying a bigger turbo.
    1996 galant s
  12. #452
    Ok so i have decided on the meth kit after reading about it all day today lol. So im going to buy one on friday, also read up on a better turbo that im going to buy this friday also, just got to wait for my credit card payment to go through since i payed it off.
    1996 galant s
  13. #453
    get car running and then get a better turbo?
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  14. #454
    the turbo that i have is a piece of shit, i took it to a guy yesterday and and he said get rid of it they are junk turbo's so im going with a better one if you want i can pm you to show you the one that im going to get, dont want everyone knowing plans so far incase i can not do it or something.
    1996 galant s
  15. #455
    check pm!
  16. #456
    fixed
    1996 galant s
  17. #457
    12-27-2005
    Charleston SC
    1,520
    shit give me the ebay 20g. Ill run it on something!
  18. #458
    01-24-2007
    481
    What turbo are you thinking?
  19. #459
    Its between two different ones now thanks to ivory lol. They are both 60 trim turbos one is a little more expensive but it can directly mout to my manifold and I can get a 02 housing that will mount right up to it and use my 3" down pipe, so I can spend the extra 100 bux bolt it on or save the 100 bux and have to do more fab work. I'm going to have to modify my manifold for a wastegate or buy a new one with a external wastegate mount on it. (Posted from my phone might be messed up ill edit when I get home)
    1996 galant s
  20. #460
    08-13-2008
    Waterbury, CT
    3,331
    if i were you i wouldnt worry about adding the wastegate to the mani as you said youd have to fab or change things either way. get the wastegate setup put on whatever O2 housing you decide on. thats what im doing when i go to the 20g or 30r
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
