these count to right?
^well that is just an awful and uncalled for tease Dave, and will not be tolerated in this forum, you should be banned for a day.... lolz, give us a hint so we can start guessing, like an offset, a width, a tire size, not all of them, maybe just one ?
1996 galant s
hahaha. Good cause i was just making sure that my new set of rims are aggressive then BITCH"S!
1996 galant s
for the record, my setup right now is 19x8.5 +48mm VOLK RACING SF-WINNING w/ 235/35zr19 NITTO INVO, dropped more than 3" AND camber corrected... that's why the offset had to be so high. camber correcting pushes the tops of the tires OUT so my rear wheels are actually pretty flush compared to cars that have don't have camber correction. i could lower offset and camber to clear, but that's not what i was going for when i bought the wheels... maybe the next setup.
this was with my old 225/35zr19 TOYO PROXES (notice stretch) when the rear bumper was being fabricated. you can also see where the cut into the fender well starts and how it gets thinner towards the top:
here are side shots from old photoshoots:
the CF center cap close-up:
bump
and my FINAL wheel fitment question
18x9 +31 with 235/40/18? lowered on Tein S-techs
will it fit? I'm willing to roll my fenders
let's do some math.
you had 18x7.5 +48 w/ 235/40r18 right?
the new size is 18x9 +31 w/ 235/40r18 right?
your inner clearance will be 2mm less.
the wheel will stick out 36mm more.
the TEIN S-tech drop is not that deep so you may be able to get away w/ it w/ negative camber and cutting out ur rear fenders. you have a much better chance of fitting them if you stretch 225/40r18 on instead of 235/40r18.
Here you go. ;-)
Much Respect.
Be Blessed.
Shane
not my style but def well executed
looks sweet shaneb.
you live in williamsport? not too far from where i live
