Thread: How to remove the trim around the radio and heater
Showing results 1 to 11 of 11
    hi
    i need a little help in my 99 galant ,, i dont know how i remove the trim around the radio and heater ,, there are some tutorials here about that but nothing is like it is in my car
    it looks like this exept for the carbon :)
    11-13-2007
    -OKC-
    3,970
    You just pull on it. I believe it's held by clips.
    yeah but it is so stuck im afraid to break something ,, are there any screws that are holding on ?
    Yes there are screws, in either wheel well you need to pop off the panel to the left and right of the bezel there is a screw on each side holding in the tray
    01-19-2007
    Lyndhurst, NJ
    3,473
    nvm
    I think JoeRad is talking about the JDM Galant, where this post is actually listed under.
    what wheel well in the dash?
    NEWBIE Fully's Avatar
    07-22-2007
    Christchurch, New Zealand.
    22
    Just pull the cover straight up around the gear stick.
    Pull the gear stick to the back of the car then pull the surround out - pull out from the bottom.
    Sif sig ..|..
    "Ping is King"
    Experienced TGC Member fliegendaffe's Avatar
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    use a plastic pry tool and take it slow to pop it off
    ^credit card or room key works perfecto! for the shifter trim...
    you wanna take more care than just yanking!!! use a flat screwdriver on the side of the gear surround forst then 4 key areas on the surround by the stereo and by the heater controll then it wil ljust pop out
    www.qcustoms.co.nz
