Originally Posted by
mko
if your hands are small youll be able to reach the middle bots. Its easy to get it out, but its hard to bolt the middle bolt down. also there are 2 bolts that hold the mani to the block thru a bracket. you need to go under the car and undo them or you really have to have flexible hands to reach behind the AC compressor.
best tool to use is 12mm ratchet wrench
taking the fuel rail for more clearance, but Ive done it w/o taking it off
be careful of leavin any left over pieces of gasket stuck to the head and the manifold
