It depends on the width of your wheels.
Ok..i went over the proper tire size sticky and im kinda not sure bout it. I jus a got a set of 215/55r17 for my new 17"s comin and Im not sure if everythings gonna clear..i'm guessing it will but could someone say For sure??
They should clear width wise unless your offset is like 35 or lower, but you got the wrong size completely. 215/55-17 is 4.2in more in circumference then 195/65-15 which is stock. I have 225/45-17 which is the exact same circumference as stock.
